Displays various show output for mirror instances.
| mirror_name | Displays the mirror name. |
| mirror_name_li | Displays mirror instance name for Lawful Intercept account only. You must have lawful intercept user privileges to specify this variable. |
| all | Displays all mirror instances. |
| enabled | Displays only enabled mirror instances. |
| control_index | Selects the particular mirror MIB instance, as defined by a control index (1–4), to show information about. |
N/A.
Use this command to display mirror statistics and determine if mirroring is enabled or disabled on the switch.
The mirror instance for a remote IP address is only installed in hardware if the status is “Up.Active”.The following command displays switch mirroring information:
# show mirror
DefaultMirror (Disabled) Description: Default Mirror Instance, created automatically
Mirror to port: -
PolicyMirror-1003 (Enabled)
Mirror Destination Indices: 1 - Enabled
Description:
Mirror to port: 3
TunMir (Enabled)
Mirror Destination Indices: 3 - Enabled
Description:
Mirror to remote IP: 192.168.97.100 VR : VR-Default
From IP : 192.168.97.184 Ping check: On
Status : Up
Mirrors defined: 3
Mirrors enabled: 2 (Maximum 4)
HW filter instances used: 0 (Maximum 128)
HW mirror instances used: 0 ingress, 0 egress (Maximum 4 total, 2 egress)
Remote IP protocol type: Trans Ether Bridging (0x6558)
Destination Control Index 1: Enabled (Active)
Destination Control Index 3: Enabled (Active)
The following example displays output for a lawful intercept user session:
* show mirror
Mirror to port: -
law_mirror (Enabled)
Description: user for lawful intercept
Mirror to port: 3
Source filter instances used : 2
Port 7, all vlans, ingress only
Port 8, all vlans, ingress only
main_mirror (Enabled)
Description:
Mirror instance for Admin
Mirror to port: 2
Source filter instances used : 1
Port 10, all vlans, ingress only
Mirrors defined: 3
Mirrors enabled: 2 (0 with egress filters)
HW filter instances used: 3 (Maximum 128)
Remote IP protocol type: ERSPAN v1 (0x88BE)
The following example shows mirroring to remote IP addresses:
# show mirror
analytics_chicago_1 (Enabled)
Description:
Mirror to remote IP: 5.1.1.2 VR : VR-Default
From IP : Auto source IP Ping check: On
Priority : 50
Status : Up. Active
Mirror to remote IP: 4.1.1.2 VR : VR-Default
Priority : 40
Status : Up. Standby
Mirror to remote IP: 3.1.1.2 VR : VR-Default
Priority : 30
Status : Down. Ping timed out
Mirror to remote IP: 2.1.1.2 VR : VR-Default
Priority : 20
All ports, vlan v1, ingress only
analytics_seattle_2 (Enabled)
Description:
Mirror to remote IP: 5.6.7.8 VR : VR-Default
From IP : 10.1.1.1 Ping check: Off
Priority : 50
Status : Down. No route
Port 2, vlan v2, ingress only
bldg_1_sniffer (Enabled)
Description:
Mirror to port: 5
All ports, vlan v3, ingress only
Mirror to port: -
Mirrors defined: 4
Mirrors enabled: 3 (Maximum 4)
HW mirror instances used: 3 ingress, 0 egress (Maximum 4 total, 2 egress)
The following example shows information about Mirror MIB instance for control index "1":
# show mirror 1 Destination Control Index 1: Enabled (Active)
This command was first available in ExtremeXOS 15.3.
The mirror_name_li variable was added in ExtremeXOS 15.3.2.
Mirroring to remote IP addresses information was added in ExtremeXOS 22.4.
Mirror MIB instance (control index) information for policy-based mirrors was added in ExtremeXOS 30.2.
Redundant remote IP address information was added in ExtremeXOS 30.4.
GRE protocol type for mirror-to-remote IP addresses was added in ExtremeXOS 30.5.
